Activity Forums Adobe Premiere Pro Desktop HD editing advice?
  • Desktop HD editing advice?
    Posted by Scott Mcauliffe on June 19, 2008 at 6:20 am
    Just wanted to run these specs by you all to get thoughts on whether they would work as a good, versatile editing set up for a smaller operation… I’ll be editing in Premiere CS3 with a lot of After Effects work and will be dealing with mostly HD footage (usually a mixture of DVCPRO HD and HDV).
    Computer:
    HP workstation xw8600
    two Intel Dual-Core Xeon x5260 / 3.33GHz
    8GB of RAM
    NVIDIA Quadro FX 4600
    two 500 GB internal SATA-300 7200rpm
    Windows Vista Enterprise (don’t have much of a choice here)
    Already have the monitors
    I’ve been working on a HP laptop (9440) which has been fine for short SD projects, but when we jumped into HD work, I seem to crash Premiere on a regular basis. Any info or thoughts would be great since editing with HD is pretty new for me.
    Thanks in advance.
    Cheers,
    sm
    Scott McAuliffe
    Urchin Multimedia Design
    http://www.urchinmultimedia.com
    Scott Mcauliffe replied 18 years, 3 months ago 2 Members · 2 Replies
  • Harm Millaard
    June 19, 2008 at 3:45 pm
    Instead of X52xx CPU’s, consider E54xx CPU’s, the Harpertown, preferably the E5472. Check that the mobo has the Intel 5400 chipset (Seaburg). Add some more disks to your system, get a good raid controller (Areca) and you should be fine.
    Harm Millaard
  • Scott Mcauliffe
    June 27, 2008 at 2:19 am
    Thanks for the reply, Harm… I appreciate it.
    Scott McAuliffe
