Activity Forums Adobe After Effects Designing graphics for 8K
  • Designing graphics for 8K
    Posted by Glen Jennings on May 6, 2013 at 4:57 pm
    Hey have any of you designed graphics for 8K?
    I am assigned to create graphics for a full dome at a Planetarium-
    They want me to deliver my image sequence to them flat and they will ingest it with their software (Dome Master) to the curvature of the dome. So I essentially get to work in After Effects and then they handle to dome specific part.
    I am curious if anybody on this forum has had any experience designing motion graphics at such a large size-8K.
    Do you have any workflow tips & tricks? Any suggestions are welcome.
    I am aware that the lower part of the frame will be the front of the dome theater. I’m still wrapping my head around the notion of designing in a format that will be projected to a circular surface…I’m curious how my 3D effects will look once they’re warped.
    Also I have not found a lot of literature on this subject online. Any links welcome.
    Walter Soyka replied 13 years, 4 months ago 3 Members · 5 Replies
  • Tudor “ted” jelescu
    May 6, 2013 at 6:27 pm
    Couple of suggestions:
    1-Render out several simple test animations and ask them to let you see how the final result looks like- there’s nothing like first hand experience.
    2- If you can use vector elements only ( AI or Shape layers) you’ll be able to work at a lower comp size and then just use the Script that comes with AE to scale up to 8k with no loss in quality.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Glen Jennings
    May 6, 2013 at 7:06 pm
    Great suggestions, thanks.
  • Walter Soyka
    May 6, 2013 at 8:01 pm
    [Glen Jennings] “Hey have any of you designed graphics for 8K? “
    Yes, pretty often.
    Get as much RAM as you can, and get a fast SSD for the cache.
    Use proxies while you work.
    Render to image sequences, not movies.
    [Glen Jennings] “They want me to deliver my image sequence to them flat and they will ingest it with their software (Dome Master) to the curvature of the dome. So I essentially get to work in After Effects and then they handle to dome specific part.”
    Ok… I’d be sure to do a test. Even better if you can build a couple tests and see them in person.
    [Glen Jennings] “I am aware that the lower part of the frame will be the front of the dome theater. I’m still wrapping my head around the notion of designing in a format that will be projected to a circular surface…I’m curious how my 3D effects will look once they’re warped.”
    One way to build real fulldome content in Ae is by working in 3D space with a hemicubic camera rig — though you would still need some software to stitch this into a properly mapped hemisphere.
    There are some dedicated plugins for working with domes in Ae.
    In either case, it may be best to press your planetarium contact for more information on producing proper fulldome content.
    Some good terms for Google searches: dome, fulldome, hemicube, hemicubic, (alternately hemi-cube and hemi-cubic), fisheye.
    Walter Soyka
  • Glen Jennings
    May 6, 2013 at 8:20 pm
    Thanks Walter. Seriously valuable information. The gravitas of this undertaking is sinking in….
  • Walter Soyka
    May 6, 2013 at 8:27 pm
    [Glen Jennings] “Thanks Walter. Seriously valuable information. The gravitas of this undertaking is sinking in….”
    You’re welcome.
    Alternate suggestion for working with flat graphics: put flat graphics near the center/top of the dome where the distortion is relatively mild and put abstract or smeary stuff around the edges where the distortion is most severe.
    Optionally bulge the center stuff a bit to try to offset the distortion. This will require some testing or math to get right. Send them a grid, have them run it through their software, and have them send it back to you to get a sense of what you need to reverse.
    Test!
    Walter Soyka
