designed my own custom foam insert for Canon C200 + Pelicase 1610
I’ve designed my own custom foam insert in AutoCad for my Canon C200 + Accessories. I precisely measured every part to fit nice and smoothly into the insert. The foam was sandwiched together and I also let them add a white sheet in between to make it look more sexy! The case type is a Pelican 1610.
https://www.schweinert.com/blog/files/78d5db341e73df3d0b7d607bf3ff6b7b-86.html
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
