Desaturated, too bright footage after rendering
Hey everyone!
I’m having some trouble with rendering out my footage(s).
They become desaturated (color loss) and bright for some reason.
I tried different render methods, codecs, formats…almost same result on each of them.
Here is a picture, it can explain better:
The original footage is much darker, and may lack of some detail, but it more colorful.
Also, the color loss/brightening is only visible on the rendered movie (doesn’t matter which codec or video player I use) – usually I use h264.I do short animations as well, in AE. If I trie to render it out in AE, I get the same result.
First time, I noticed this problem, I rendered out a 40 min footage, and something was off. I couldn’t fix this issue, and for some reason, I checked some old footage. They ahd the same problem, but I did not notice it before (see below – picture).
https://oi42.tinypic.com/2mwulg2.jpgI’m using Adobe CS6, Windows 7 64bit.
Thanks in advance!
