Activity Forums Adobe Premiere Pro Desaturated Colors After Export Premiere Pro CC
  • Desaturated Colors After Export Premiere Pro CC
    Posted by Faraz Mozafarian on June 11, 2014 at 6:46 pm
    Hello,
    I’ve tried searching this topic but have not found much or at least not a solution.
    When I do an export out of Premiere Pro CC I notice that the colors are slightly desaturated. In the source monitor it looks fine but when compared side by side with the export the colors are slightly muted.
    I’ve tried several different codecs/bit rates but get the same result every time.
    I’m on a mac.
    Any ideas?
    Thank you
    Faraz Mozafarian replied 12 years, 3 months ago 2 Members · 2 Replies
  • Dustin Parsons
    June 11, 2014 at 10:19 pm
    Are you viewing your export in PPro or another application like QuickTime? If you’re looking your exported video in QuickTime or Safari it’ll look more washed out because their color management is different from Adobe’s standards.
    Take a look at this thread where I had a similar problem: https://forums.creativecow.net/thread/335/66624
  • Faraz Mozafarian
    June 11, 2014 at 10:57 pm
    OK. Yeah. It looks better in VLC.
    Thank You!
