Derive hidden corner pin point from other three
I’m wondering if there is a way to calculate where one corner of the corner pin effect should be based off the position of the other three (given an initial starting point). I have a screen replacement where three of the points are visible, and can track individually and bind to nulls. However the fourth remains off screen. Might anyone be aware of a solution? I would try the parallel corner pin tracker, but it wont allow me to pull the fourth point off-canvas.
