Activity › Forums › Adobe After Effects › Depth of field suddenly stopped working
Posted by Jon Simpson on October 26, 2015 at 7:20 pmI have a simple comp with multiple 3d layers and a camera set up. The depth of field was working fine with focus moving from front to back and now everything is suddenly just flat. Depth of field and blur are enabled, all layers are still in 3d space – I have no idea what happened. What did I do or what could have happened?
Jon Simpson replied 10 years, 10 months ago 3 Members · 12 Replies -
Cassius Marques
October 26, 2015 at 8:09 pmcan you show us a screenshot of your viewport and your timeline with the camera layer showing all properties?
Jon Simpson
October 26, 2015 at 8:31 pmHowever, when I get back to active camera view, I still have no depth of field.
Cassius Marques
October 26, 2015 at 8:38 pmwell, for a start your blur level is very high(I almost never touch that property), you should start resetting things to the default values and if you want more blur increase apperture. maybe recreate a camera from a preset and check if it gets back then start copying/pasting values untill you see whats making it go away
Jon Simpson
October 26, 2015 at 9:27 pmI tried all of this and nothing fixes the problem. It has to be some other setting that toggles the depth of field on and off or a pita bug. Nothing makes sense.
Jon Simpson
October 26, 2015 at 9:31 pmWhen I put in a new camera and start completely from scratch, none of my setting modifications have any effects on the depth of field. Everything stays flat.
Jon Simpson
October 26, 2015 at 11:08 pmI did add a 2d layer at one point but that was made 3d immediately. I mean, I made it a 3d layer immediately to make it work it within the other layers.
Jon Simpson
October 27, 2015 at 12:00 pmThis started when I applied an ease to a position key frame on one of the layers. I have no clue how that could have caused this but I still cant get my depth back.
