Activity › Forums › Adobe After Effects › Depth of field on camera not affecting particles in particular
  • Walter Soyka
    July 6, 2010 at 12:31 pm
    Particle types “glow sphere” and “star” do not support depth of field. Also, in Particular’s effect controls, Render Settings > Depth of Field should be set to “Camera Settings.”
    Walter Soyka
  • Mitch Hardison
    July 6, 2010 at 1:24 pm
    I am using 1.5.1 and I do not see a render setting. Hopefully they are set to camera settings by default. Thanks a lot
  • Walter Soyka
    July 6, 2010 at 1:32 pm
    [Mitch Hardison] “I am using 1.5.1 and I do not see a render setting.”
    On Particular 1.5, it was called “Render mode.” I don’t remember what the default was.
    Here’s some documentation on depth of field with Trapcode 1.5. What I said before about particle type still applies; make sure that your particle type doesn’t say “No DOF.”
    Walter Soyka
  • Mitch Hardison
    July 6, 2010 at 2:30 pm
    Ok I found the setting. You are the man! Thank you so much
