Activity › Forums › Maxon Cinema 4D › Depth of Field in post – Front Blur issue
  • Depth of Field in post – Front Blur issue
    Posted by Brian Murphy on April 4, 2012 at 5:11 pm
    This may be more of an After Effects question but I know many of you most likely follow the same workflow as myself. We render out in passes in C4D, then composite and add effects in After Effects. I have been banging my head against the wall trying to remedy this and just need a straight answer.
    So many people talk about doing DOF in post but they NEVER mention a frontal blur issue that I can’t get around. Check out the attached graphic. The top shows an unblurred image with no DOF for reference. The bottom shows using the depth pass as my depth matte. I can never use this reliably with frontal blur effects because the object tries to blur within the actual border of the death pass, causing a sharp edge (refer to yellow arrows). Am I missing something or is this just not possible in post? I was never even able to get a decent true blur in Frischluft. (sp?)
    Thanks guys!
    Brian
    Brian Murphy replied 14 years, 5 months ago 4 Members · 5 Replies
  • Bill Kelly
    April 4, 2012 at 11:47 pm
    This is just a guess here, but what were your anti-aliasing settings in C4D for the original image? Looking closely at the original image, I can see aliasing right in the same spots you have the arrows pointing in the bottom image. Perhaps this is causing the depth pass to not interpret the distance as accurately as it should. Maybe try setting your anti-aliasing in C4D a little higher and see if that works.
    To see tutorials, articles, tips, free stuff, and more visit my post-production blog at https://thekellzone.com
  • Bill Kelly
    April 4, 2012 at 11:51 pm
    Actually, looking closer at the top image, I can see aliasing on all the balls. It doesn’t seem to have a problem if they are not near the border, but when they are it looks like it’s an issue. I’d set my Anti-Aliasing to Best and at least 2×2 min and 4×4 max and see if that works.
  • Darby Edelen
    April 7, 2012 at 11:03 pm
    What effect are you using to apply your DOF in After Effects? This one is my favorite:
    https://www.frischluft.com/lenscare/index.php
    Give it a try and see if it handles the scene any better.
    That said, this blur bleed at the edges of overlapping objects is a problem with all the post DOF effects I’m aware of. I believe it has to do with the effect estimating the coverage of the objects and not quite getting it right.
    Darby Edelen
  • Cassius Marques
    April 10, 2012 at 2:38 pm
    yep, that’s the bane of post DOF…Try rendering your depth with double your resolution and no AA. let AE scale it to 50%…
    It helped me before.
  • Brian Murphy
    April 11, 2012 at 7:19 pm
    Hmmm, interesting approach – thank you all for your answers! I’ll experiment with your ideas.
    Cheers,
    Brian
