Activity › Forums › Maxon Cinema 4D › Depth of Field focus range?
  • Depth of Field focus range?
    Posted by Joe Morris on April 5, 2013 at 8:21 pm
    I’m quite new to Cinema 4D and I’m experimenting with Depth of Field, although I can’t figure out how to increase the range of focus. Like, it will only let me focus on one part, making things that are a little in front of it and a little behind it blurry.
    Daniel No replied 4 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Brian Jones
    April 6, 2013 at 4:50 pm
    which renderer are you using? It’s different setup depending if you are using the Standard or Physical renderer.
  • Joe Morris
    April 6, 2013 at 5:46 pm
    Physical.
  • Brian Jones
    April 7, 2013 at 1:06 am
    it’s a lot easier in the Standard render where you can just set the limits visually (not physically accurate but easier) but Physical is based on the rules of real cameras so depth of field is controlled by Focal Length, Sensor Size (Object tab of the camera) and FStop (Physical tab of the camera) — the easiest way to control depth is the FStop – increase that and the depth should get bigger
  • Joe Morris
    April 12, 2013 at 6:30 pm
    I want to make the area which is in total focus bigger.
  • Kenn Baynard
    April 13, 2013 at 8:14 pm
    Are you talking “Focal Distance?” If you adjust or animate that parameter you can basically “roll the focus” during the course of the animation. You’ll find it in the “Object” tab. If you want to increase the amount of blur then you’ll have to lower the f-stop. Sometimes to really low numbers to make a difference (like 0.25, etc..)
    In real world optics when you lower the f-stop you’re opening the camera’s iris allowing more light in, allowing you to achieve depth of field by focusing on an object by using a combination of focal length and iris settings (generally meaning you need to be zoomed in on an object to achieve DoF). In C4D’s physical renderer you’re simulating real optics by allowing similar controls. But unlike the real world you can take the f-stop down below f/1.0 to allow you to achieve DoF in smaller environments where objects may be close together, and you don’t have to adjust the focal length of the camera.
    You could also play with the DOF Map Front Blur and Rear Blur settings under “Details”. Those are present in both renderers.
  • Joe Morris
    April 18, 2013 at 1:13 pm
    I want to change how much is in focus DoF-wise.
  • Lee Yang
    February 19, 2015 at 5:32 pm
    The higher the Fstop, the less DOF. F 1.2 will give you a narrow focus point. F 8 will give you a larger focused area.
  • Daniel No
    July 4, 2022 at 12:44 pm
    This is literally the best description of what Fstop does that summarizes it in one easy sentence. Bravo and thank you! –a n00b who doesnt know much, but is learning.
