Activity Forums Maxon Cinema 4D Depth of Field and Alpha Channel
  • Depth of Field and Alpha Channel
    Posted by Jason Connolly on February 23, 2007 at 10:52 pm
    Hi, folks-
    I’ve researched the posts here regarding my problem and I just want to make sure I have this right.
    I have a scene with several objects spinning on a floor. I apply DOF, and it looks great in C4D, however, when I bring that Targa sequence in After Effects for compositing, the alpha channel has hard edges and doesn’t follow the DOF blurring at all. Is this true that this is a limitation in C4D??
    Jason
    Philip Hahn replied 14 years ago 4 Members · 4 Replies
  • Mylenium
    February 24, 2007 at 3:59 pm
    [Jason Connolly] “Is this true that this is a limitation in C4D??”
    Yes, it is.
    Mylenium
    [Pour Myl
  • Jason Connolly
    February 24, 2007 at 4:20 pm
    Rats! Thanks, Mylenium.
    –Jason
  • Greg Serafin
    February 26, 2007 at 11:28 pm
    Won’t go to all the details as I don’t remember 100% what I did, but…
    Output the DOF to separate image sequence, and use it to blur the ALPHA image sequence.
    Load the edited ALPHA – and you are done!
    IQ0
  • Philip Hahn
    September 11, 2012 at 12:22 pm
    However, only using “rear blur” will work with correct display of the alpha channel. Sometimes this will meet the desired effect.
