Activity › Forums › Adobe After Effects › Depth map from 3D objects in comp? How?
Posted by Brian Murphy on May 3, 2011 at 11:05 pmHey all,
Is there a way to get a depth map out of 3D objects in an After Effects comp?
I have a camera and rendered animation brought into AE from Cinema 4D. Picture an environment full of cells scattered around. I only rendered the main cell that plays to the camera with an alpha in Cinema 4D and will populate the scene behind it with flat images of cells in 3D space but to get depth of field and have them fade into the far distance, I need to somehow get a depth map from all those 2D objects that I turned into 3D in my comp. Any idea how?
BrianMichael Szalapski replied 15 years, 3 months ago 4 Members · 5 Replies -
Brian Murphy
May 3, 2011 at 11:34 pmIn answer to my own question, I did happen to find this….
https://www.digieffects.com/product/atmosphere
But can I isolate alpha’s 3d layers and NOT affect a background image?
Hmmmmm.
Kevin Camp
May 4, 2011 at 4:26 pm[Brian Murphy] “but to get depth of field and have them fade into the far distance, I need to somehow get a depth map from all those 2D objects that I turned into 3D in my comp.”
i’m not sure you need a depth map to do that… what would you use it for? dof can be set up within the ae camera, or you can use expressions to link a blur to the distance between the layer and the camera.
you can use a similar expression to link that same distance to a layer’s opacity or an effect that would help it blend into the background (actually, i f you needed a true depth matte from ae, you’d use a similar expression to link distance from camera to opacity of the layer, hide the background and render just the alpha channel)…
anyway, you’ll find a good expression here:
https://www.motionscript.com/design-guide/falloff.html
in that example, dan uses it in the material properties of 3d layers to simulate light falloff, but you could use it in a layer’s opacity, or in the source opacity of an effect like solid composite if you wanted it to change color rather than opacity…
to make it relative to the camera, you can either parent a light to the camera and set the light position to 0,0,0, or, if you don’t need the light (ie, not using the material properties), you can change one line of code to:
L = thisComp.layer(“Camera 1”); // use the name of your comp camera
to effect blur (if you’re not using the camera’s dof), you could use an expression like this in the blur property of an effect like fast blur:
decay = 100;
focalDist = 500;
d = length(L.transform.position,transform.position);
Math.abs(d-focalDist)/decayKevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Walter Soyka
May 4, 2011 at 10:08 pm[Brian Murphy] “Is there a way to get a depth map out of 3D objects in an After Effects comp?”
Yes — Digieffects Depth [link].
[Brian Murphy] “I have a camera and rendered animation brought into AE from Cinema 4D. Picture an environment full of cells scattered around. I only rendered the main cell that plays to the camera with an alpha in Cinema 4D and will populate the scene behind it with flat images of cells in 3D space but to get depth of field and have them fade into the far distance, I need to somehow get a depth map from all those 2D objects that I turned into 3D in my comp. Any idea how?”
I agree with Kevin — you might not need a depth map to do this. Why not just use DoF in AE’s camera?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Brian Murphy
May 5, 2011 at 5:45 pmDepth of field is great for blur and that works fine but I really need to sell the effect of distance by having the further objects take on more of the background color to simulate fog or murky liquid. Kevin’s script was awesome and I will use that for the camera and objects distanced from it…the depth map was mainly to apply the color effect toward the furthest objects. I can’t use opacity for this because at times, there are objects that go behind them and the would show through.
Thanks guys!
Brian -
Michael Szalapski
May 10, 2011 at 5:27 pmYou could apply some color correction effects to give your layers that atmospheric look and tie the amount of color correction to the distance from the camera with expressions. Once you have it set up for one layer, it should be fairly easy to copy it to the others.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
