Activity Forums Maxon Cinema 4D depth map adjustment
  • depth map adjustment
    Posted by Nicholas Toth on May 6, 2008 at 3:08 pm
    Hey guys
    I’m trying to adjust the depth map for a virtual scene that has been projection mapped onto geometry, and I can’t figure out how. Basically, when I output a depth map, I get a very small gradient on the bottom of the screen, where the floor is, but I need it to flow back into the geometry.
    I’m working in 32 bit, and I’m trying to up the exposure in AE, and it isn’t working.
    Thoughts?
    Nicholas Toth replied 17 years, 5 months ago 4 Members · 6 Replies
  • Adam Trachtenberg
    May 6, 2008 at 4:37 pm
    The depth pass depends on the camera’s depth settings. As it happens I did a small video tutorial on this a few months ago, which you can see here:
    https://www.3danvil.com/tutorials/DOF_Effect/DOF_Effect.html
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Nicholas Toth
    May 6, 2008 at 5:17 pm
    Thanks Adam!
  • Josh Crews
    April 7, 2009 at 4:43 pm
    This is a great post. Exactly what I’ve been searching for all morning.
    It is missing one important step though. He says that you need to enable the depth post effect in order to achieve depth of field. He bypasses how to enable it.
    Does anyone know how?
    Thanks again Creative Cow for saving the day.
    Josh
  • Nicholas Toth
    April 7, 2009 at 5:06 pm
    2 options!
    1. Enable ‘depth’ in your multipass settings
    2. Enable Depth of Field in your effects settings
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Josh Crews
    April 7, 2009 at 5:14 pm
    Where is the effects setting?
    Thanks again.
  • Nicholas Toth
    April 7, 2009 at 5:18 pm
    In your manual. I’d recommend checking there first.
    No seriously, in your render settings, but it depends on which version of cinema you are running, they moved them in v11.
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
