Activity Forums Creative Community Conversations Deprecated QuickTime Codecs Temporary Fix
  • Deprecated QuickTime Codecs Temporary Fix
    Posted by Andrew Richards on November 20, 2013 at 6:08 pm
    I saw this on the Apple Support Forums and thought it would be of interest here:
    [westinmylifeaway] “You can re-enable many of the legacy codecs usable in QuickTime Player 7 with the following [Terminal commands]…
    qtdefaults write LegacyVideoCodecs ApplePlanarRGB enabled
    qtdefaults write LegacyVideoCodecs SorensonVideo enabled
    qtdefaults write LegacyVideoCodecs SorensonVideo3 enabled
    qtdefaults write LegacyVideoCodecs AppleBMP enabled
    qtdefaults write LegacyVideoCodecs AppleCinepak enabled
    qtdefaults write LegacyVideoCodecs AppleH261 enabled
    qtdefaults write LegacyVideoCodecs AppleH263 enabled
    qtdefaults write LegacyVideoCodecs AppleMotionJPEGA enabled
    qtdefaults write LegacyVideoCodecs AppleMotionJPEGB enabled
    qtdefaults write LegacyVideoCodecs ApplePNG enabled
    qtdefaults write LegacyVideoCodecs AppleNone enabled
    qtdefaults write LegacyVideoCodecs AppleVideo enabled
    qtdefaults write LegacyVideoCodecs AppleGraphics enabled
    qtdefaults write LegacyVideoCodecs AppleTGA enabled
    qtdefaults write LegacyVideoCodecs AppleTIFF enabled
    qtdefaults write LegacyVideoCodecs AppleComponentVideo enabled
    qtdefaults write LegacyVideoCodecs AppleJPEG2000 enabled
    qtdefaults write LegacyVideoCodecs ApplePixlet enabled
    If you also want to enable all of the “legacy audio codecs” you can copy this line to your terminal:
    qtdefaults write LegacyAudioCodecsEnabled yes
    More details on the original post at https://discussions.apple.com/message/18075187#18075187
    These should enable both QTPX and QuickLook playback support (following a logout/login), though I have not tested this yet. This fix should only be considered temporary for Mavericks, as the next major rev of OS X may very well not support some or all of these legacy codecs at all. It is still a good idea to start transcoding your old content to modern supported codecs.
    Best,
    Andy
    Michael Gissing replied 12 years, 10 months ago 2 Members · 1 Reply
  • Michael Gissing
    November 21, 2013 at 1:04 am
    Many thanks Andrew. Very useful info
