Activity › Forums › Adobe After Effects › Deprecated Premiere-After effects copy/paste workflow issue
  • Deprecated Premiere-After effects copy/paste workflow issue
    Posted by Jurij Magoga on March 1, 2016 at 6:18 pm
    I’ve been using for a while the copy/paste workflow for moving my edited clips from Premiere sequences to After Effects compositions, and found that I like it much more than Dynamic link.
    After last updates though this workflow became very buggy, i.e. sometimes it paste just one clip or it keeps pasting the first copy i do, like it was not able to flush the clipboard when new clips are copied in.
    Quitting and relaunching apps doesn’t work.
    Anyone has experienced this behaviour?
    Any solution?
    Thanks in advance 🙂
    Jurij Magoga replied 10 years, 7 months ago 2 Members · 2 Replies
  • Michael Szalapski
    March 1, 2016 at 7:29 pm
    You could also try using the File>Import Premiere Pro Project command. It’s separate from the regular import command and it should bring your whole Premiere sequence with each edit on its own layer.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Jurij Magoga
    March 2, 2016 at 7:29 am
    Thank you Michael, your workaround certainly works, but I feel very handy the copy/paste thing and if it is still there it would be fine if it worked properly.
    Anyone has noticed that after last updated of PPro and Ae the copy/paste stopped working properly.
    I’m on osx el capitan with ae 13.7 e ppro
