Activity Forums Apple Final Cut Pro Legacy dependent nests in FCP
  • dependent nests in FCP
    Posted by Alex Udell on July 7, 2006 at 10:58 am
    Hi All…
    If I collpase several clips on a timeline into a nested sequence…
    then on main timeline duplicate that nest….
    If I open the nest and make a change to the content…
    Only one reference on the main timeline is changed….
    Is there a way to duplicate it on the main timeline so all refernces reflect the change (the change propogates to all refernces)…
    Thanks…
    Alex
    David Bogie replied 20 years, 2 months ago 2 Members · 1 Reply
  • David Bogie
    July 7, 2006 at 3:27 pm
    Use the nest’s icon that appears in the Browser. If you use copies of a nest from a timeline, you get an independent copy of the nest, not a dependent version.
    It’s quite confusing but, now that you have had some trouble with it, you might benefit from re-reading that section of the manual about nesting and how the different versions of a nest are treated in the Canvas and Browser.
    bogiesan
