Activity Forums Maxon Cinema 4D Dented box
  • Dented box
    Posted by Nick Bruzek on April 6, 2018 at 11:47 am
    So I’m trying to make a box with a letter on either side pushing the sides in a little bit like they are all squished together. Sounds really simple but for the life of me I can’t seem to figure it out
    Jim Scott replied 8 years, 5 months ago 3 Members · 5 Replies
  • Steve Bentley
    April 6, 2018 at 5:51 pm
    Is it as simple as the bulge deformer with a negative setting? (the deformer is a child of the box object and the box has to be editable – so a parametric cube won’t work – up the segments on the cube before you make it editable so you have enough polys to make the deformation smooth.)
  • Nick Bruzek
    April 6, 2018 at 7:30 pm
    Thanks!! I had tried this earlier, but forgot to subdivide so it wasn’t working
  • Jim Scott
    April 6, 2018 at 9:14 pm
    Just for clarification, a parametric cube will work as long as it has more than one segment. And obviously the more segments it has, the smoother the deformation will be.
  • Steve Bentley
    April 6, 2018 at 10:37 pm
    (Slaps forehead). Of course it will. I’m so used to people working with deforms and the number one reason its not working is they havent hit the C key.
    Jim, I guess we’re gonna have to auction off that “Genius” Propeller Beany. We’ll split the proceeds.
  • Jim Scott
    April 6, 2018 at 11:52 pm
    Sometimes I get lucky. You keep the beany.
