Activity › Forums › Adobe Premiere Pro › denoising speech – which Audio effects and to apply and in what order?
  • denoising speech – which Audio effects and to apply and in what order?
    Posted by Daniel Kislyuk on September 28, 2006 at 9:24 pm
    Hi!
    I’m a psychologist and use Adobe Premiere to create auditory stimuli for the subjects of my cruel experiments. So the quality I need is not too high, but I want the best I can achieve with current knowledge (almost 0) and software – dobe Premiere Pro 2.0.
    I have a pretty bad recording of the Finnish lady reading a text and I need to take away the constant hiss that appeared due, I think, to the built in mic of the camera.
    Right now I’m doing it this way
    -auditory gain 10dB
    -volume 0dB
    -DeEsser (without it after passing the stream through denoiser there is a strange metallic echo after certain sounds)
    -DeNoiser (reduction -8.5, offset 6.5)
    -EQ (50 Hz -20dB; 120Hz -17dB 1.33oct;1232Hz 15dB 2.66oct;3020Hz -16dB 2.73oct;10000Hz -20dB;output -1.2dB)
    this results in moderately good speech with still some hiss in the background and some “metal” introduced by denoiser.
    Q1. What could i improve?
    Q2. Could you recommend me tutorial on speech improvement for the beginners?
    Q3. almost offtop. How to scale the amplitude of the waveform in the timeline to make it occupy all the space given for the track?
    Dave Friend replied 20 years ago 3 Members · 5 Replies
  • Vince Becquiot
    September 28, 2006 at 11:26 pm
    You could look into the parametric EQ to isolate the frequency a little better.
    The truth is, the hiss will never go away without the frequencies pertaining to the voice.
    Vince
  • Daniel Kislyuk
    September 28, 2006 at 11:51 pm
    thanks! it worked fine when i overlapped regular EQ with a parametric one. may be it’s totally unprofessional but it works.
  • Dave Friend
    September 29, 2006 at 12:30 pm
    Daniel,
    You might want to consider picking up a copy Adobe Audition. It has some great noise reduction, hiss, click and pop filters that are reasonably easy to use.
    Dave
  • Daniel Kislyuk
    September 29, 2006 at 12:55 pm
    Are the denoising tools in adobe audition any different from the ones implemented in CoolEdit 2.0?
    -daniel
  • Dave Friend
    September 29, 2006 at 10:08 pm
    Pretty much the same but with some improvements/refinements. In particular, the ability to lasso a specific range (time and frequency) to use as a noise sample. Just this week I used it to remove the persistent squeak, squeak, squeak from a fan in an air handling system without mucking up the speakers voice. Very cool.
    Dave
