Activity Forums Adobe After Effects DE:Noise fails to render errors
  • DE:Noise fails to render errors
    Posted by Phil Kurus on October 5, 2014 at 9:41 pm
    Hey All:
    FCP 7, DE:Noise and DE: Noise Frame Average, latest versions. Latest CUDA driver installed. MacBook Pro mid-2012. 1 GB VRAM. OSX 10.9.5
    GFX Card Status indicates that FCP is using the GPU as it starts.
    New purchaser of DE: Noise.
    I keep getting render failures and their error message pop-ups.
    Two problems:
    1. Individual clips in the timeline (1080i ProRes) will sometimes fail to render, but I can usually skip to a different frame and start over with success. HOWEVER, other, previously rendered clips will suddenly revert to RT orange unrendered status! This means that rendering each clip individually won’t work.
    2. A full render of the Timeline (Export, QuickTime movie) is impossible. It consistently trips up with a fail to render on one of the DE:Noise plugins, though which instance I don’t know.
    What am I missing here? Any help greatly appreciated.
    Cheers.
    Phil Kurus replied 11 years, 11 months ago 2 Members · 2 Replies
  • Peter Litwinowicz
    October 6, 2014 at 5:22 pm
    Hello back,
    Not sure what’s up. You might be running out of memory. (FCP 7 is notorious for this).
    How many frames are you trying to accumulate with DE:Noise Frame Accumulate? Also are there any other plugins before DE:Noise (this can cause issues with memory requirements).
    Note that DE:Noise does not use the GPU, so there’s nothing for DE:Noise to set or unset there.
    Perhaps you can send us your FCP 7 project (no media needed just yet)
    and I’ll take a look. Make sure to tell me what sequence to look at.
    send the project to us at techsupport (at) revisionfx (dot) com.
    Pete
  • Phil Kurus
    October 7, 2014 at 7:17 pm
    Pete–looks like my partner received your answer via the support link. Thank you.
