Activity › Forums › Adobe Premiere Pro › DeNoise effect on all dialog track clips vs applying the effect in the Audio Track Mixer for that track – Premiere Pro 2019
Posted by Yair Bartal on July 23, 2020 at 6:28 amAre these two options equivalent?
Herb Sevush replied 6 years, 1 month ago 3 Members · 6 Replies -
Oliver Peters
July 24, 2020 at 6:23 pmThey typically aren’t the same, because many de-noise audio plug-ins require some section without talking in order to calculate a noise print to remove that sound from under the dialogue. The better option is to send the audio clip to Audition and use its tools to clean up the track. Then bounce it out (processed and rendered) as a separate clip to use back in Premiere.
Other plug-ins like de-essers and so on on can probably be used on either clip or track. From a workflow standpoint, it’s best to group similar sounding clips onto separate tracks and then do all of your processing on the track, not individual clips. For example, A1 – SOT dialogue, A2 – VO, A3 – SFX, A4- music.
– Oliver
Oliver Peters – oliverpeters.com
Yair Bartal
July 24, 2020 at 6:43 pmThanks Oliver for your response,
As I understand, none of the two options I’ve mentioned is generally better than the other, even for only one person talking.
Am I correct? -
Oliver Peters
July 24, 2020 at 7:10 pmIf you are using a denoise filter, you typically need have some empty audio (but not blank audio or complete silence) from the track there before the person speaks in order for the effect to properly process. Assuming you have that, then clip or track work the same. But t depends on the plug-in you are using. Some require rendering and others work in real-time.
– Oliver
Oliver Peters
July 24, 2020 at 7:18 pmPS: If you specifically mean this effect in Premiere (#1 in the YT video) –
then it works the same way whether applied to the clip or the track.
– Oliver
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Herb Sevush
July 27, 2020 at 5:49 pmI believe adaptive noise suppression works better in the track mixer because it’s comparing the past sound to the present sound and then making adjustments. If you go clip by clip the initial moment of each clip has no previous noise print to go by and you might hear a little audio pumping at each cut.
Herb Sevush
Zebra Productions
nothin\’ attached to nothin\’
\”Deciding the spine is the process of editing\” F. Bieberkopf
