Activity › Forums › Apple Final Cut Pro Legacy › demuxing HDV files captured with FCP (for blu-ray)
Alfred Guzzetti replied 13 years, 3 months ago 7 Members · 40 Replies
Emmanuel Presselin
November 6, 2011 at 2:09 pmI use ffmpeg 0.0.9y on mac with graphical user interface, so there’s command line.
Bouke Vahl
November 6, 2011 at 2:21 pmwell, do toy with the command line, and get a static build.
It’s really not difficult once you get the hang of it.Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Emmanuel Presselin
November 6, 2011 at 2:28 pmWhere can I find the command line version for mac ?
Any idea ? -
Bouke Vahl
November 6, 2011 at 2:34 pmwell, a google for ffmpeg binary mac gives you this:
ffmpegmac.netBouke
Eric Pautsch
November 8, 2011 at 8:42 amIm a little embarrassed since I author Blu-Ray discs for a living but I was unaware that 1440×1080 MPEG2 stream have been added to the spec. Good work!
Emmanuel Presselin
November 8, 2011 at 9:24 amYes it’s part of blu-ray specs. And it can help us with mpeg-based footage, like HDV.
If someone come a cross a good tool to demux HDV streams so that we can use it straight for authoring, let us know ! that was the very first point of this message 🙂Emmanuel
Eric Pautsch
November 8, 2011 at 9:53 amA better site to ask this question would be https://www.videohelp.com
I used:
https://www.videohelp.com/tools/TsRemux
and
https://www.videohelp.com/tools/ProjectX
They worked fine
Bouke Vahl
November 8, 2011 at 10:25 amwell, i’ve made a very simple FFmpeg front end (user interface)
Get it here:
https://rcpt.yousendit.com/1278959790/6467658a42fca7a430276d587d680851Unzip, do not remove the Xtras folder!
Run it, pick a file, it will be demuxed to filename.mpg and filename.aif, and it WILL overwrite existing files!
(so don’t pick a .mpg file as input…)hth,
Bouke
Emmanuel Presselin
November 8, 2011 at 10:41 amBouke, you’re the man !!!
You are a mpeg wizard…This app is gold !! Works like a charm. Fast and easy.
This app is the perfect tool. I”ve read so many posts desperately asking for a way to play and use HDV files from Final Cut on Windows app.You should do something with this…
Beautiful.
Emmanuel -
Bouke Vahl
November 8, 2011 at 11:44 amwell, i do something with this, it’s my living 🙂
(see my site..)I do stuff like this also highly customized for specific questions, and normally i get paid for my work.
But this was so simple (about the command line i’ve wrote earlier) that writing the invoice would have been a major factor of the time involved…If it works for you, great, keep it and use it!
Bouke
