Activity › Forums › Apple Final Cut Pro Legacy › Dell 2407 Monitor Problem
Posted by Caton Clark on October 9, 2007 at 5:05 pmI just bought a dell 2407 and the DVI-D cable that came with it didn’t match the DVI port on my G5.
I’ve got it hooked up using the VGA to DVI adapter, but I’m wonderif there’s a way to connect using the actual DVI ports.
Does DVI-D require an adapter to plug into an apple DVI port?
Thanks for any help.
Jeremy Garchow replied 18 years, 11 months ago 4 Members · 6 Replies -
Walter Biscardi
October 9, 2007 at 6:56 pm[cmc2008] ”
I just bought a dell 2407 and the DVI-D cable that came with it didn’t match the DVI port on my G5.”Are you sure it’s a DVI port on your G5? We have two of these monitors running in our shop and one of them uses the stock Dell DVI cable. The other uses a longer, standard DVI cable.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Steve Eisen
October 9, 2007 at 7:06 pmThe stock DVI cable from my Dell did not work with my G5 Dual 2.5. I used a different DVI cable and all is good.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Caton Clark
October 9, 2007 at 7:17 pmSteve –
Do you happen to know what kind of DVI cable you got to replace the one that came with the monitor?
Thanks.
Jeremy Garchow
October 9, 2007 at 8:34 pmWhat kind of graphics cards do you have and are you sure it’s not an Apple ADC connection?
If so you will need an ADC to DVI adapter.
All recent Apple cards and displays are finally standardized to DVI, thankfully, but older cards might have an ADC connection on them.
Jeremy
