Activity Forums Apple Final Cut Pro Legacy Delivering in 720P but filmed in 1080P what would you do?
  • Delivering in 720P but filmed in 1080P what would you do?
    Posted by Rubin Polizzi on August 17, 2011 at 4:19 am
    Hey everybody so I just want to double check my thinking here and to see what others would do.
    I am working in FCP7 and the final delivery is a 720P ProRes file. The footage was shot on a 5DMKII at 1080P, I am thinking that I will edit in 1080P (1920×1080) then in the end Output the final file at 720P (1280×720). This is my thinking would you do anything differently ?
    Frame rate is 24fps for both the source and delivery.
    Chris Wiggles replied 15 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 17, 2011 at 3:23 pm
    That will certainly work OK.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Chris Wiggles
    August 17, 2011 at 9:50 pm
    I would output the master file in 1080p, then scale and/or compress to whatever you need using compressor, etc.
    I shoot 1080 (i, usually) all the time, and when I compress for the web, I just compress to 720p off the exported 1080 final product.
    Regards,
    Chris
