Activity Forums Apple Final Cut Pro Legacy Delivering an FLV
  • Delivering an FLV
    Posted by Bruno Silva on May 18, 2010 at 2:23 pm
    Whats the best way to create an flv file from a final cut mov.? My tools are Final Cut Studio 2 and Mpeg Streamclip. I need to deliver an flv for a client over the web. The clips are standard NTSC.
    Bruno Silva replied 16 years, 3 months ago 9 Members · 10 Replies
  • 10 Replies
  • Walter Biscardi
    May 18, 2010 at 2:38 pm
    We use Telestream Episode. Studio won’t do that and I’m not sure about MPEG Streamclip.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Mike Simpson
    May 18, 2010 at 3:18 pm
    I’d agree with Walter and go with Episode – it’s pretty good value and very very capable.
    I understand that sorenson and autodesk have products too but not sure how much they cost compared to episode.
    Happy encoding.
    Mike
  • Bruno Silva
    May 18, 2010 at 3:44 pm
    man $500 is pretty steep for an up n comer like myself. I’m downloading the trial version, hopefully it wont watermark the clip. But I’ll also look into alternatives. Thanks
  • Craig Sawchuk
    May 18, 2010 at 3:45 pm
    Can’t you just export an h264 file from Compressor and then change the extension to .flv? ‘Think this will only play on newer versions of Flash, but depending on your client’s needs it may work with the software you’ve got..
  • Bret Williams
    May 18, 2010 at 4:41 pm
    Yes. Never had a problem. They’d have to have a pretty old version of flash. I’ve been doing this since someone posted this little trick about a year ago. No problems yet. Flash started supporting h.264 about 2-3 years ago so I suppose that’s when this started being an option.
  • Rainer Wirth
    May 18, 2010 at 6:41 pm
    I use on2 plugin for FCP successfuly. It’s about 200 bucks.
    Rainer
  • Jean-christophe Boulay
    May 18, 2010 at 8:13 pm
    Do you have Perian installed on your system? If so, FLV should be an export option in QT. I don’t know how reliable it is but it could be worth a look. ffMPEGx also does FLV.
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Neal Broffman
    May 18, 2010 at 8:45 pm
    Brett and Craig are correct here…use QT and export as h264. Change the extension from .mov to .flv and you will be fine. This works for me and I have never had a problem.
    Neal Broffman
    One Production Place, Atlanta, GA
    “Voices of Freedom”, Special Jury winner for Fall 2008 CINE Awards produced for the High Museum of Art in Atlanta as part of a major exhibition of vintage Civil Rights Movement photographs, “Road To Freedom”. Currently on display at The Bronx Museum (through August) after having been on exhibition at the Field Musuem in Chicago, The Skirball Cultural Center in LA and The Smithsonian in DC.
  • Aaron Brenner
    May 19, 2010 at 6:41 pm
    Do you own After Effects CS4 or CS5? If so, they bundle “Media Encoder” which does a great job at FLV compression. Don’t expect it to handle SD anamorphic 16:9 though… for that, you’re back to Episode.
  • Bruno Silva
    June 3, 2010 at 2:56 pm
    Can you give me a step by step of the h264 to flv workflow? I just need to be caucious and run this out smoothly. I have compressor.
    Assistant Editor
    http://www.harringtontalents.com
