Activity › Forums › Adobe After Effects › Deletion of ‘frames’
  • Deletion of ‘frames’
    Posted by Alejandro Diaz on February 2, 2010 at 4:26 pm
    Hello everyone, new here. Actually fairly new to After Effects in general, so hoping this is not one of those completely idiotic questions, pardon me if so. I am primarily a flash animator, so trying to adjust to the interface and workflow of AE as I experiment.
    What I am trying to do is to make everything to the right of the playhead to sort of slide to the left. In Flash I would just delete frames to adjust the entire thing without having to individually select and edit each layer and move them to an earlier point in the timeline. Am I missing something or is there an easy way to do this rather than having to move each item in my composition?
    thanks, and so far loving AE!
    -alej
    Alejandro Diaz replied 16 years, 8 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 2, 2010 at 5:05 pm
    I think that you’re looking for the Lift Work Area feature, which does a ripple deletion (removes a segment and closes the gap). Try it and see if it does what you’re after.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Alejandro Diaz
    February 2, 2010 at 5:17 pm
    Actually it was ‘extract work area’ that worked the way I wanted, but wouldn’t have found that without your tip, thanks!
