Activity Forums Panasonic Cameras Deleting unwanted P2 media in P2CMS
  • Deleting unwanted P2 media in P2CMS
    Posted by Philip Fay on June 16, 2008 at 7:11 am
    Is this possible, I have a 1 hour clip of a bird nest and just want to remove the exciting 2 mins (in 2 locations on the clip) to free up some disk space. I see you can set in/ out points butbut do not know how to completely delete the unwanted sections…..hopefully its simple?
    Tom Klein replied 18 years, 2 months ago 3 Members · 2 Replies
  • Noah Kadner
    June 16, 2008 at 8:19 pm
    Just make a new archive P2 MXF.- It can’t delete unused portions from existing shots. My recommendation would be to create an uncompressed version in QuickTime as well if you’re intending to truly wipe away your main archive- which normally I wouldn’t recommend. In this case however, it sounds wise as you’ll never want the remainder of the shot.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook and Sound for Film and TV.
    https://www.callboxlive.com
  • Tom Klein
    June 22, 2008 at 10:56 am
    Hi Philip,
    I would use Premier 3.1.1 and import from the P2 card the whole file into the timeline Mark your In and out pitnts then simply export a P2 MXF file, I have done this many times, it works a treat and is very fast. just export the section to another location/drive/P2 card, your choice.
    Cheers
    Tom K
