Activity Forums VEGAS Pro Deleting unwanted frames (a better method requested)
  • Deleting unwanted frames (a better method requested)
    Posted by Jonathan Hay on February 8, 2006 at 8:27 pm
    I have a very convoluted way of deleting unwanted scenes and I was hoping there is a better way to do this in vegas 6.
    I have 3 or 4 camera angles on different tracks, with a master on the top. When I run into a scene that I want to cut I split (s) at the first and last frame that I want to delete. Then I create a region on the top. Then I clip on the left split and drag the left side of the region to lock on this point. I then repeat for the right side. Then I select the region (shift Q) and delete and move everything over.
    Is there a better way to delete between two frames that you have picked out?
    Jonathan
    Gary Kleiner replied 20 years, 7 months ago 2 Members · 1 Reply
  • Gary Kleiner
    February 8, 2006 at 9:21 pm
    > Make a time selection of the area you want to delete
    >Ctrl/A to select all
    >Delete
    >Ctrl/F to ripple the gap closed
    >Ctrl/Shift?a to deselect everything
    BTW, if you are doing multi-camera editing, you definitly should check out Excalibur.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
