Activity › Forums › Adobe Premiere Pro › Deleting Render Files…. Consequences?
  • Deleting Render Files…. Consequences?
    Posted by Mike Schmitt on April 16, 2005 at 8:38 pm
    Hi there:
    I’ve got a wierd problem where my original 16;9 files work, but any file I alter by adding effects to or import after manipulating them in After Effects shows up as a 4;3 in the Program Monitor.
    It is 16;9 in the Source Monitor and after I export the files they turn back into a 16;9.
    All settings are 16;9 where I know to change them and when I intrpret footage, it shows up as 720 x 480 widescreen.
    I’m thinking about deleting my render files and rerendering the project. WHen I start I get a warning that all files will be deleted. I just want to make sure that I am not going to be making a mistake I can’t repair.
    If I delete render files, will I be okay to just rerender the entire work area?
    MIKE
    Steven L. gotz replied 21 years, 5 months ago 2 Members · 1 Reply
  • Steven L. gotz
    April 16, 2005 at 9:23 pm
    Yes. Just delete the render files (also called Preview files) and then render. I do this now and then just to keep drive space requirements down.
