Deleting Previous Shot, Not the next
Posted by John Perez on May 10, 2022 at 10:03 pmWhen I slice a shot and hit delete it deletes the next shot. Can I make the previous shot before the cut to be deleted, instead of the shot after the cursor?
Graham Bernard replied 4 years, 4 months ago 4 Members · 8 Replies -
Red-rob Rothkopf
May 10, 2022 at 10:25 pmHi John!
So you’re splitting an event (“s” key) and want to delete the previous event (on the left of the split), yes?
Try ALT-[ to invoke “trim start” — it deletes from the start of the event where the scrubber is on the timeline up to the scrubber position 🙂
Unrelated — I’m curious why you seem to post here instead of on the forum at http://vegascreativesoftware.info ?
🙂 Rob
John Perez
May 11, 2022 at 3:00 pmJust habit. Do u think I’d be asking a larger pool of experts than here? Also, is that forum sponsored by Vegas Pro?
Edward Troxel
May 12, 2022 at 3:56 pmWhen pressing “S”, the event AFTER the split will be selected. The option given by Rob will cut off before the cursor or you could write a script that does what you want.
Graham Bernard
May 13, 2022 at 9:34 amWhen I slice a shot and hit delete it deletes the next shot. Can I make the previous shot before the cut to be deleted, instead of the shot after the cursor?
John! Use the Trimmer. It will do exactly what you want. You don’t need a script. You need to appreciate The Mighty Trimmer and release your creativity. 😎
John Perez
May 13, 2022 at 12:49 pmAhh yes, the trimmer–which I don’t like, but let me give it another go at it, Grazie. Thx!
Edward Troxel
May 18, 2022 at 1:43 pm -
Graham Bernard
May 18, 2022 at 2:19 pmOr use what you’ve paid for – The Mighty Trimmer. But learning a new skill set is always rewarding. Personally, it’s the Trimmer for me. 😉
