Activity Forums Adobe Premiere Pro Deleting Premiere Pro Projects
  • Deleting Premiere Pro Projects
    Posted by John D zupan on January 6, 2006 at 4:35 pm
    Good Day
    This is my first post on this site.
    I came over from Descreet Logic Edit
    Just received Premiere Pro Axio HD editing system and I been play with settings and now I would like to delete the projects ( Test#1, Test#2 )and start fresh with actual projects.I can’t find any refrence to deleting projests in the PP Manual.
    Any help would be appreciated.
    John
    John D zupan replied 20 years, 8 months ago 3 Members · 5 Replies
  • Marisu Fronc
    January 6, 2006 at 4:43 pm
    John-
    Just delete the pproj file (it resides where ever you originally directed them.
    slainte,
    marisu
  • John D zupan
    January 6, 2006 at 5:05 pm
    Thank You Marisu
    John
  • Larry Sherwood
    January 6, 2006 at 6:31 pm
    This will delete the project file only, not the media associated with it. The way I do it is to open the project, note the locations that my scratch disks setting are set to, and then manually go to those locations to archive or delete the media. You can also use Project Manager to Trim the project first which will create a new folder containing all required files for this project, a great way to archive.
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
  • Marisu Fronc
    January 6, 2006 at 7:44 pm
    Larry-
    I assumed that he only wanted the project to stop coming up in the list (duh . . . my brain now ONLY does EXACTLY what is asked) guess I should have taken it the extra step – thanks.
    slainte,
    marisu
  • John D zupan
    January 7, 2006 at 4:25 pm
    Thanks Larry
    I did find were the scratch disk setting were and they were set to the same file as my capture settings were. i did delete everything and started fresh.
