Activity › Forums › Panasonic Cameras › Deleting P2 files
Deleting P2 files
Posted by Jeff Wilmes on April 27, 2007 at 1:19 pmI’ve also posted this in the FCP forum, but wanting to know why I can’t delete p2 files from my drives. I’m getting a message saying the the files, lastclip and mxf, are locked and the trash cannot be emptied.
Mau Singh replied 15 years, 10 months ago 7 Members · 9 Replies -
Arthur Luhn
April 27, 2007 at 3:33 pmDrag the files out of the trash, click each file once (highlight) then go file>get info and on the general list uncheck the “locked” option. Trash again.
I avoid dumping stuff on the desktop by dragging directly from P2 cards to my hard drives and then eject P2 card and delete/reformat in camera.
If anyone has a better method, I’d be glad to hear it.
Jeff Wilmes
April 27, 2007 at 4:51 pmThanks, I had same reply in the FCP forum. Alot of files to uncheck the “locked” box. I already had the files backed up and on the shelf, I was trying to just dump these off my RAID. Not sure how the files got locked. Maybe in the transfer from Laptop to external drive then external drive to RAID?
Shane Ross
April 28, 2007 at 6:54 amHold down the OPTION key while you empty the trash.
No need to get info and unlock them…that is WAY too time consuming.
Shane
Littlefrog Post
http://www.lfhd.net -
Eric Hansen
May 1, 2007 at 11:20 pmin my case, this did not work. Xsan does not allow you to drag something to the trash and hold it there. similar to a mounted server drive. when you drag a P2 card folder to the trash, it says “This folder will be deleted immediately”. holding OPTION down during any of this process doesnt do anything. a window still comes up saying that the files are locked.
i’ve got quite a few GBs of MXF files to delete from my Xsan. any suggestions?
thanks
e
Brandon Thomas
April 8, 2009 at 11:45 pmDid you ever solve this? I have the same issue.. unable to delete locked P2/MXF files from our xsan..
thanks!
Alexander Hemingway
September 16, 2009 at 10:23 pmI’m waiting with brimming drives to find out the solution to this one as well. anyone?
Brandon Thomas
September 16, 2009 at 10:26 pma utility called batchmod (linked below) allows you to reset any permissions or unlock any files. It was the only solution i found. works wonders.
https://www.macchampion.com/arbysoft/Welcome.html
Mau Singh
November 20, 2010 at 4:46 amThis problem is well known and finally I found solution for it:
https://pathtoodeep.com
