Activity Forums Avid Media Composer Deleting Locked Files
  • Deleting Locked Files
    Posted by Mario Biennarc sioco on July 15, 2009 at 12:15 pm
    How can I delete locked clips? I try to unlock them in the bin but I just can’t. There’s a message that comes up and says filename cannot be unlocked! I can’t delete them using the MDV avid either. It’s eating to much space on my harddrive and I can’t find a way to unlock them. Help, please?
    Mario Biennarc Sioco
    Videographer & Video Editor
    Gulf Broadcast
    Kingdom of Bahrain
    Mario Biennarc sioco replied 17 years, 2 months ago 4 Members · 5 Replies
  • David Braswell
    July 15, 2009 at 1:11 pm
    Try unlocking them through Explorer or the Finder if you’re on a Mac. In Windows, right-click on folder containing files, view properties, and uncheck the read-only attribute.
  • Steve Pankow
    July 16, 2009 at 4:53 pm
    Use your OS to search your drives for files with a .lck (lock) extension and delete them.
  • Mario Biennarc sioco
    July 19, 2009 at 5:08 am
    It’s the clip itself that is locked. I checked all the project bins and made sure that there are no .lck files. I also tried right clicking and removing the read only attributes. But when I click it again, the read only attributes become checked again. 🙁 Too bad I have other projects in the AvidMediafiles folder so I can’t just format the drive. Any other solutions?
    Gulf Broadcast
    Kingdom of Bahrain
  • Stu Mccoll
    July 20, 2009 at 2:29 am
    Hi Mario.. I had the same problem and it is a matter of setting permissions on the folder that the files reside in. This is what worked for me:
    Start->Run->”explorer”->(Navigate to Folder)->(Right Click On Folder)->Sharing & Security->(Check) Share this folder on the network->(Check) “Allow network users to change my files”.
    Try it. Hope it works for you!
    Stu.
    July 20, 2009 at 5:47 am
    You are brilliant!!! Thanks buddy!
    Gulf Broadcast
    Kingdom of Bahrain
