Activity Forums Boris FX Deleting FCP Prefs causes Problems
  • Deleting FCP Prefs causes Problems
    Posted by Tim Langston on August 18, 2006 at 10:03 am
    I’m running FCP 5.1.1 on a G5 Quad, everytime I delete FCP Prefs I loose the ability to use RED and also Continuum. It takes away the button to access the settings. I then find that I have to re-install the update and everythings once again fixed. I use FCP Rescue, does that have anything to do with it?
    Just wondered, are we looking at huge speed increases when the Mac Pro versions come out?
    Tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
    Tim Langston replied 20 years ago 2 Members · 2 Replies
  • Chris Paul
    August 18, 2006 at 7:27 pm
    Are you doing the shift-lock trick? (Delete the cache, start FCP with lock on, immediatly quit, then start FCP with lock off). There is a known issue with Boris and FCP 5.1.1 where the controls for Boris disappear but are restored by this trick.
    I don’t know if FCP Rescut could causing trouble- It has definitly saved my bacon in the past.
    Chris Paul
    POV
  • Tim Langston
    August 18, 2006 at 7:31 pm
    So after deleting the prefs… do the cap lock trick. Next time I have to delete prefs I’ll give it a try.
    Tim
    Tim Langston
    Fort Wayne, IN
