Activity › Forums › Adobe Premiere Pro › Deleting effects in multiple clips
Roger Averdahl replied 8 years, 3 months ago 12 Members · 16 Replies
Jonas Bendsen
May 14, 2014 at 12:53 amRight. All of the effects are gone, even if you only want to remove one effect from hundreds of clips with multiple effects… so now you have to go back to each clip (hundreds) and reapply the effects you didn’t want to delete. Not really a feasible solution.
This is my life, I edit and edit and edit and edit…https://TeahmBeahm.com
https://Digabyte.com -
Filip Goc
June 13, 2018 at 3:29 amThis is a very old thread, but it still comes up in google… so here comes.
In Premiere Pro CC 2018 (not sure when this was introduced), you can select any clips you want, then right click and “Remove attributes…”
Then a dialog lets’ you select any number of attributes to remove! All, some, whatever.
Tadaaa.
Roger Averdahl
June 13, 2018 at 9:58 amThe problem is that it for some reason does not work in CC2018. When i use it to remove Effect filters nothing happens…
Can you add let´s say Lumetri Color to a clip and then go to Edit > Remove Attributes and remove it from the clip by un-checking Lumetri Color and click OK? 🙂
Filip Goc
June 13, 2018 at 6:02 pmIt works for me.
So far I used this successfully with:
– audio effects in audio clips
– lumetri and crop effects in regular clips (even if the effects are mixed or different and with different settings)all in all it just seems to work.
My system as of testing this: Mac Sierra, Premiere Pro CC build 224
Filip Goc
June 13, 2018 at 6:04 pmRoger, I have an idea:
It seems that you are unchecking what you want to remove – as in the Lumetri effect.
But in the Remove Attributes dialog, you need to _check_ what you want _removed_.
Good luck.
Roger Averdahl
June 14, 2018 at 12:26 pmFilip, i totally missed that and yes it works. I have used that feature before but it seems that i had a coma-moment and fogot how to use it…
Thanks for the follow up! 🙂
