Activity Forums VEGAS Pro Deleting all key frames
  • Deleting all key frames
    Posted by Stefan Schramm on October 2, 2017 at 8:20 am
    Hi guys,
    is there a command to delete all keyframes from a clip, preferably even several clips at once. In this case, I copied event attributes to a bunch of clips, but found it wasn’t such a good idea.
    Stefan
    Vegas 12, Windows 7 Professional
    Stefan Schramm replied 8 years, 11 months ago 2 Members · 2 Replies
  • Francois Pénzes
    October 3, 2017 at 11:11 am
    Hi Stephan
    There may be a better way of doing this out there but this is how I do it:
    1- Go to your Keyframes
    2- Select the first keyframe you want to delete and left clic.
    3- With the shift key down, go to the last keyframe and left clic. You can also selectively choose the keyframes you don’t need by using the Ctrl key.
    All selected keyframes will have a white dot in the middle.
    4- Right clic on one of the selected keyframes and Presto ! No more keyframes !
    This was made while keeping in mind that not everyone is at the same level of proficiency in VPro.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
  • Stefan Schramm
    October 6, 2017 at 12:53 pm
    Hi Francois,
    while not as quick as I had hoped for, this is still far better than selecting every last key frame individually!
    Stefan
