Activity › Forums › Apple Final Cut Pro Legacy › deleting all affiliate clips tied to one master – How?
  • deleting all affiliate clips tied to one master – How?
    Posted by Kent Kajino on July 8, 2006 at 6:56 pm
    Is there a way to catch all the affiliate clips tied to a master clip in order to delete them all, including all clips referencing them?
    (search of the entire FCP forum did not turn up anything)
    What I have is an offline sequence in DV, which I would like to bring online in an umcompressed 1080 60i sequence. The original footage is a mixture of HDV and HDCAM footage. I can blow up the HDV footage in-house, but I need to go to a post house to capture HDCAM. In order to provide the post house with an estimate of footage to recapture, I want to delete all references to the HDV clips in my sequence.
    After I have a sequence devoid of HDV affiliates, I will make the HDCAM clips independent, then use the media manager to estimate the bare minimum of HDCAM footage that I need to capture.
    So far, I’ve found that the entire sequence with both HDV and HDCAM with un-needed media taken out blows up to 1.4TB of data at 10-bit Uncompressed 1080 60i.
    Kent Kajino replied 20 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    July 8, 2006 at 7:36 pm
    Export an EDL of a copy of the sequence after you’ve removed the HDV clips from it. This will end up with a list that contains the TC of only the HDCAM footage.
    Jerry
  • Nick Meyers
    July 9, 2006 at 12:38 pm
    i think they want a quick way to first delete all the HDV footage.
    it would be great if you could do an intelligent timeline search, looking for just one flavour of footage,
    or, as this is all in DV res, all clips of a certain reel#.
    but you can’t
    so here’s what i’d do:
    copy the sequence, place it in a new project
    tools menu: create master clips
    figure out some way to separate the HDV from the HDCam shots in the browser.
    gotta be reel# i guess, as everything is still DV.
    select all the HDV shots in the browser, and make offline.
    timeline HDV clips also go offline.
    now do a Media Manage on the sequence
    chose RECOMPRESS, and choose an HD flavour
    tick Delete unused,
    and there;s your media usage.
    if you dont have any HD option in hte recompress list you may need to download some drivers & codecs from blackmagic or kona.
    otherwise do a Media Manage without recomporessing, and do the maths youself.
    seriously. given the time spent figuring this out, and up-resing the HDV,
    would you just as well off to capture everything, HDV included, at the facility?
    nick
  • Tom Wolsky
    July 9, 2006 at 1:17 pm
    Can’t the browser finder search by specific columns? Isn’t there something like the codec that distinguishes the HDV material that you could search for all items?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Nick Meyers
    July 9, 2006 at 2:05 pm
    yes, but the thing is that at then moment, all the media is DV, as they’re cutting off-line.
    even if they had the HDV & the HDCAM in the timeline, it wouldnt be too easy to figure in the browser:
    you;d have to make a new bin,
    copy or drag all your timeline clips to there (so you had them with in/outs)
    sort by type, delete all your transitions generators, graphics, etc.
    then sort by codec.
    and even then you wouldnt have any handles on the clips that had transition on them.
    (although now i read your post again, i don’t think this is what you’re suggesting… still… it;s all DV)
    cheers,
    nick
  • Tom Wolsky
    July 9, 2006 at 2:18 pm
    That’ll teach me to read the whole thread first. You’re quite right, there really is no simple way to do what the writer wants.
    All the best,
    Tom
  • Arnie Schlissel
    July 9, 2006 at 3:03 pm
    In the browser, you can use “Find” to search for all clips from a particular reel name that’s used in a specific sequence.
    In your timeline, you can use “Find” to search for all clips that have the same name.
    Of course, you would have to have logged the footage with proper reel names & not renamed the affiliate clips in the sequence for this to work.
    Arnie
    https://www.arniepix.com
  • Nick Meyers
    July 9, 2006 at 10:16 pm
    yes, and had something very identifiable in that reel name – not us the letter “a” for instance.
    like (HDV) or ^ or something.
    and as you point out, every time you make a subclip, you;d have to remember to include the reel# in the name.
    roll on intelligent timeline search!
    nick
  • Kent Kajino
    July 10, 2006 at 9:20 am
    (Forgot to turn on email notification…)
    I think the last post nailed it on the head. Probably didn’t work the first time I tried it, because I didn’t have the sequence hilighted in the bin when I tried the Find funcion.
    I had the clips labeled according to its acquired format, so I’m able to extract only what I want.
    Thanks!!!
