Activity Forums Avid Media Composer Deleted Sequence Help
  • Deleted Sequence Help
    Posted by Anthony Miale on January 19, 2008 at 8:00 pm
    I ran into a problem when I moved some media from one bin to another in two separate projects. After the move into the new project, I opened the Audio Suite which caused Avid to crash. When I re-launched, the bin I moved the media into was empty, as was the bin I moved it from.
    I went into the Media Tool and was able to get all my source material, but the sequence is nowhere to be found. I know the Media Tool doesn’t load sequences, but is there anyway to get it back?
    I’m working with Xpress Pro 5.7, and the crash happened as the Audio Suite was loading effects. It got to 87% and crashed. The ironic thing is I was separating Sequences into their own bins so things just like this could be avoided.
    Any help would be greatly appreciated.
    Michael Thomson replied 18 years, 7 months ago 2 Members · 1 Reply
  • Michael Thomson
    January 21, 2008 at 9:55 am
    Hi
    Have you checked previous bin versions in the attic?
    The Chump
