Activity › Forums › VEGAS Pro › Delete Time Interval Out Of Timeline, From All Lines At Once?
  • Delete Time Interval Out Of Timeline, From All Lines At Once?
    Posted by Peter Alvin on August 2, 2009 at 2:13 am
    I’d like to be able to cut out, say, three seconds from various parts of my timeline. I know I can split each then drag the parts on the right over to the left until they meet.
    I was hoping I could select a range of time on the top (with the yellow arrows) then click Edit > Cut or Edit > Delete but that seems to do nothing.
    Is there any easy way to delete time from timeline?
    Peter Alvin
    Mike Kujbida replied 17 years, 1 month ago 3 Members · 4 Replies
  • Mike Kujbida
    August 2, 2009 at 4:17 am
    Do what you were doing as far as selecting a time range and then press the Delete key.
  • Terry Esslinger
    August 2, 2009 at 11:08 pm
    And if you have auto ripple enabled the right part will automatically shift over and join with the left part.
  • Peter Alvin
    August 13, 2009 at 1:00 pm
    Mike,
    I think I’m doing what you’re saying. Well, first of all, I press CTRL-A to select all tracks, then I click then drag to create a time region above the timeline so two yellow arrows are created.
    I then hit the Delete key and things change but it’s not right. I’ve tried both with Auto-Ripple enabled and disabled. I would expect all tracks to just disappear as if that time never existed but it doesn’t. A nearby track marker to the right also doesn’t seem to be in correct position.
    Any other ideas? 🙁
    Peter Alvin
  • Mike Kujbida
    August 13, 2009 at 3:08 pm
    Peter, make sure that Auto Ripple is set to All Tracks, Markers and Regions (in the drop-down menu next to the toolbar icon) when you do this.
    Also, it’s not necessary to do a Ctrl+A to select all your tracks.
    Clicking in a blank space beneath your timeline should accomplish the same thing, even if a track is already highlighted.
