Delete points base on the distance
Hey,
I was considering the scenario when I have the object and let say one single point/null next to it.
And base on the distance between the null and my mesh I would like to delete the mesh points gradually. I tried xpresso a bit today with point node but I cant figured out how to do it.
From my understanding I would need position attribute from my mesh points and the distance from my null to the mesh as a variables and then I can run if condition saying if the distance is less then something remove points from my geo. If you Guys can help my with that using python or coffee I would be delighted ????
