Activity Forums Apple Final Cut Pro Legacy delete MXF files for MOV
  • delete MXF files for MOV
    Posted by Roberto Lopez on March 25, 2008 at 2:52 pm
    I’m editing on FCP 6.0.2 and shot with the HVX200 in a 720 24pn format. Once my mxf files become MOV after ingesting into FCP, do I really need the MXF files since my mov will be my source clip in my scratch disk…it’s taking up twice the amount of space on my drives…or do I need to hold on to the MXF for some output reason, thanks.
    Roberto Lopez
    Roberto Lopez replied 18 years, 6 months ago 3 Members · 3 Replies
  • Shane Ross
    March 25, 2008 at 3:12 pm
    Just to be sarcastic for a bit, once you capture your tapes, do you throw them out? Because they are taking up all that shelf space…
    No…those are your masters. WHat if your hard drive failed and your media was lost? You’d be screwed. What you need to do is archive that footage on a firewire drive and put that on a shelf. Or what I do, archive it to bare SATA drives and put those on my shelf (cheaper). I have drive bays on my MacPro that make this easy, but Tigerdirect.com has SATA to USB adapters that make this easy.
    Do not store the MXF files and MOV files on the same drive. If you lose the drive, you’ll be screwed again.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Devin Crane
    March 25, 2008 at 3:17 pm
    Yes you can throw away your MXF files but like Shane says if something goes down you won’t have a back up.
  • Roberto Lopez
    March 25, 2008 at 3:26 pm
    thanks fellas, have the MOCs backed up on two external 1T HD and another internal HD on my system…bye bye mxfs…thanks fellas.
