Activity › Forums › Apple Final Cut Pro Legacy › Delete Media
Delete Media
Posted by Pete Sake on November 29, 2007 at 5:01 pmWhats the best way to delete unwanted Media in FCP6?
I believe I have to use ‘media manager’ but not sure of the process?
PeterMike Land replied 18 years, 1 month ago 3 Members · 3 Replies -
Walter Biscardi
November 29, 2007 at 5:17 pmIf you’re working on a project and want to get rid of unneeded media from your project…..
In the Browser select all the clips you don’t need.
Right Click on one of them. Choose “Make Offline” from the drop down menu.
Then choose “Delete From the Disk” from the next menu.
Say Ok to “This is not undoable” from the next option.
Now all the clips will go offline in your project and they have also been deleted from the drives.
If you are done with a project…..
Go into your Capture Scratch Folder on your media drives.
Throw away the Folder with the project(s) you no longer need.
Do the Same with the Render Folder.
Empty the Trash.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Mike Land
March 27, 2008 at 6:13 pmIf I delete the capture scratch folder from my hard disk, will it remove all the quicktimes associated with the timeline in FCP6? Is there a way to delete everything but the in/out markers in a clip?
Mike
