Activity Forums Adobe InDesign delete consecutive hard returns using Edit> Find/Change
  • delete consecutive hard returns using Edit> Find/Change
    Posted by Debbie Rich on November 8, 2005 at 4:13 am
    Curious if anyone knows how to delete two consecutive hard returns using the Edit> Find/Change command?
    I flow MS Word docs from my colleague into Indesign. He always separates his paragraphs with two hard returns. I can find and replace two spaces with Find/Change. But if I type the key into the Find field, that activates the ‘Find’ function.
    I’m using CS on a Mac.
    thanks! *debbie
    Debbie Rich
    debbie@digitalanarchy.com
    ph 415.462.5872
    Debbie Rich replied 20 years, 10 months ago 2 Members · 2 Replies
  • Kelly Johnson
    November 8, 2005 at 6:51 am
    The easiest way to replace anything you don’t know the ascii code for is to just simply copy the figures and paste.
    So, just copy the two return ‘spaces,’ paste into the find box then paste again into the replace box and delete one of the two characters that will appear as the code for a return.
    Find and Replace is one of the best/handy/important tools for developers!
  • Debbie Rich
    November 9, 2005 at 10:52 pm
    You know, I could have SWORN that i tried the copy/paste routine first. But of course, now that someone is watching, it worked. ;-0
    thanks! *debbie
    Debbie Rich
    ph 415.462.5872
