Activity Forums Square Box CatDV “Delete Catalog” command in “browse catalogs”?
  • “Delete Catalog” command in “browse catalogs”?
    Posted by Warwick Teale on December 10, 2010 at 6:40 am
    Guys, I understand from the cat DV pro documentation (I’m currently on version 8.1.10) that there is a command specifically to remove an existing catalogue. From the documentation it appears there is something called Delete Catalog (US spelling of course) that are supposed to be available in the “Browse Catalogs” window.
    However I Am unable to find this commend anywhere in the cat DV pro application. I don’t even see in the menus anywhere.
    Workaround: It’s not a serious issue because I’m only going to the finder and remove the catalogues and their backups manually.
    does is commend actually exist?.
    Bryson Jones replied 15 years, 9 months ago 3 Members · 2 Replies
  • Rolf Howarth
    December 10, 2010 at 8:30 am
    That could be a documentation error, or you could be getting confused with the Browse Database command which shows a list of catalogs on the server (if you’re using CatDV with the CatDV Server). But you’re right, you can just delete catalog files from the Finder.
    By the way, we long since standardised on the American spelling of catalog because “cataloguing” just looks too weird!
  • Bryson Jones
    December 16, 2010 at 1:36 am
    Rolf,
    I still can’t stop telling clients I’m going to “customise” a system for them. What do y’all have against Z’s?
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
