Activity Forums Adobe Premiere Pro Delete Audio From Video Clip Without Unlink Clip ?
  • Delete Audio From Video Clip Without Unlink Clip ?
    Posted by Deep Maithani on March 4, 2018 at 12:37 pm
    Hi
    All Greeting Of Day!
    I am finding Solution for Deleteing “Audio only” From my Video Clips Without Doing Unlink Clips
    its possible in APPro ?
    Currently I am Doing First Select Clip then Cntrl+L then again Selecting audio Cilp separately then pressing Delete !
    its taking too much time
    in Edius i Used first select the then Press Alt+C audio will be Removed !
    finding this kind of solution, Please Guide i am new in APPro
    Thanks In Advance
    Deep Maithani replied 8 years, 6 months ago 3 Members · 3 Replies
  • Syahir Ismail
    March 6, 2018 at 11:39 am
    I think I understand what you’re trying to achieve here.
    I’m a Mac user,
    Option + Mouse Left Click (Select) to select the clip individually without selecting both Video & Audio.
    Hope this is what you meant.
    Let me know if it is. Thanks.
    – An editor just transitioning from FCP 7 to Premiere Pro.
  • Roger Averdahl
    March 6, 2018 at 12:05 pm
    Hold down the Alt-key and at the same time click on the audio. This selects only the audio and now you can press Delete to remove the audio. No need to unlink since the Alt-key temporary unlink as long as the Alt-key is held down. You can do this for video as well.
    You can also hold down the Alt-key and lasso select multiple clips and delete let´s say 100 audio clips in one go.
  • Deep Maithani
    March 7, 2018 at 6:50 am
    Wow its Work!
    Thanks A Lot Sir..
