Activity › Forums › Apple Final Cut Pro Legacy › Delay pressing play
  • Delay pressing play
    Posted by Steve on January 21, 2006 at 11:29 pm
    I recently digitized 800 gigs using a 1 terabye scsi raid. Upon pressing play in the timeline, I get a five second delay or so with the beach ball spinning until the playhead responds. I had a ATTO UL2D card. I took that out and placed the ATTO UL3D card and installed the proper drivers, but still get the delay and beach ball.
    Any suggestions to alleviate the delay.
    Dual 2.0 G5, OS Tiger, FCP 4.5, 2 Gig RAM
    Ben Holmes replied 20 years, 8 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    January 22, 2006 at 2:12 am
    Don’t know if it will HELP, but (like chicken soup) it couldn’t HURT.
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Ben Holmes
    January 22, 2006 at 11:05 am
    Steve
    Two thoughts: Firstly that is a lot of the drive to use – 80 percent usage of an array will cause seek times to be increased, as final cut goes scrambling all over the place to find your video. This is a very likely cause of this delay.
    Secondly, changing over the scsi cards without clearing out the media is probably no real use, and a little scary – not sure I’d attempt it with 800 gig on the drive. You need to find other storage to copy the data over to (a few hundred clams on a firewire drive should do it, a small price to protect a lot of work) and clear the drive completely and restripe it in disc utility. You are now using a faster scsi card, and I am suprised you are reading any data at all. If you have problems copying over the data, then you probably have bad data or bad sectors on your scsi drive. Try copying files over in small groups and see if you can identify the bad files.
    If you are playing a rendered timeline, it could just be a bad render file that is causing all of this – and let’s hope it is. Clear out all the render files using render manager, and re-render everything. See if that helps at all before you try all of the above.
    Still – I would always be wary of filling up a drive too much – What you describe is a classic drive seek problem.
    Ben
    Editec Broadcast Editing Ltd
    EVS and FCP specialists
    Current Mac systems All Dual 2.7Ghz with Kona 2 and Digital Voodoo cards, 6Gb Ram, Sapphire, SCSI320 Medea and Huge Arrays.
    FCP projects include Sky TV coverage of the Ryder Cup and US Open Golf – Live OB specialists. Edit/slomo vehicle.
    http://www.editec.co.uk
