Activity Forums Apple Final Cut Pro Legacy Delay of picture on external monitor after black…
  • Delay of picture on external monitor after black…
    Posted by Marrian Johnson on January 9, 2010 at 5:58 pm
    I’ve been looking through the forum for this problem but couldn’t find it.
    Sometimes, when I playback my timeline and there’s black (no video clip) over audio for a bit and then picture comes up, there’s a picture delay on my external monitor so that it’s not in sync with my audio. Usually, if I insert a slug into the empty video space and playback, everything will be in sync after the black. Although that doesn’t work 100% of the time either. Has anyone had this issue and found a fix for it? Is it a Kona setting? I have the LHi.
    Drew Kilcoin replied 16 years, 6 months ago 3 Members · 2 Replies
  • Jeffrey Lonigro
    March 3, 2010 at 7:49 pm
    I am experiencing the same issue running SL, FCP 6.0.6, AJA LHe 7.5
  • Drew Kilcoin
    March 18, 2010 at 12:50 am
    Its a kona setting, when my project did that it was because I had it in 8bit and had to switch to 10bit on the setting i was using..
    Drew
    https://www.imdb.com/name/nm2398405/
