Activity Forums Apple Final Cut Pro Legacy Deinterlacing = Quality loss?
  • Deinterlacing = Quality loss?
    Posted by Sarah Schela on March 29, 2013 at 8:34 pm
    I have a general question:
    Does deinterlacing video material automatically mean quality loss?
    I have read that during the deinterlacing process it throws away half of the image information so that would be no question that the deinterlaced footage has less quality.
    I am deinterlacing 50i footage to 25p using Compressor.
    Sarah Schela replied 13 years, 5 months ago 3 Members · 4 Replies
  • Nick Meyers
    March 30, 2013 at 6:55 am
    i haven’t used compressor to de-interlace,
    the main problem is that you cant see your results on an external monitor
    in the past i have used the NATTRESS smart de-interlce plug in .
    it is very god, best there is for use within FCP in my opinion.
    i took the same short clip, and applied 3 different de-interlace plugins i had, and on a blind test Nattress came up best.
    nick
  • Rafael Amador
    March 30, 2013 at 9:30 am
    Nattress, ReVision FieldsKit are very good.
    Jess Deinterlacer (free) is said to be very good too.
    The FCs default de-interlacer and QT deinterlacing, are to be avoided.
    rafael
  • Sarah Schela
    March 30, 2013 at 10:03 am
    Oh yes, I tried and found out. So I started using Compressor. But good to hear, I haven’t done anything wrong!
  • Sarah Schela
    March 30, 2013 at 10:05 am
    Thank you also for all the other suggestions. But yeah, worst thing would be the built in FCP effect or QT.
    I will have a look for the other suggestions you mentioned. Thank you so much, to all, so far!
