Activity Forums DVD Authoring Deinterlacing or pixel aspect ration trouble…?
  • Deinterlacing or pixel aspect ration trouble…?
    Posted by Twotimes_170 on June 1, 2007 at 7:17 am
    I am importing betaSp content with a 16:9 pixel aspect ratio.
    I run the signal through a Dac 200.
    I get a dv avi file in 4:3. This i guess needs to be corrected to the right aspect ratio.
    At this point i see small vertical black lines around moving objects, but i understand this is normal.
    The next thing i do, is importing the file to Sorensen squeeze and then to Sonic dvd-it. However i cant seem to get rid of the black lines..! Ive tried all reasonable and unreasonable settings i can think of. If i squeeze it to a 4:3 aspect ratio and then use the de-interlace setting i vlc, the lines disappear.
    How do i get rid of the black lines. Ive search this and other forums with no luck.
    Twotimes_170 replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
