Activity Forums Media 100 deinterlacing M100
  • deinterlacing M100
    Posted by Matt Jones on May 13, 2009 at 8:34 pm
    I have a Media100HD program (1920 Prores 422HQ from 1080iHDV) that I want to output for Web and Youtube. I am having fantastic results from the “export file” command, choosing MPEG-4 and then setting up custom parameters for H264.
    The only problem is that the final compressed file shows interlacing, and I can’t figure out if I can deinterlace the source in media100 output interface. I see the the field dominance drop down, but it doesn’t seem to make a difference.
    I have also had good results with Compressor and Streamclip, using M100HD ref files as the source. If I use these apps, what settings should I use to correct brightness/gamma etc, to compensate for the 16-235 color range?
    I know someone will suggest I get Bitvice, but I’m looking for a solution with the tools I have.
    Matt Jones
    Metro Productions, Inc.
    Raleigh, NC
    Fermin Branger replied 17 years, 4 months ago 3 Members · 2 Replies
  • Olof Ekbergh
    May 14, 2009 at 2:21 am
    If you have AE, then you have the perfect tool.
    I also use Sorenson Squeeze, it works very well for flash or other web formats and has good de-interlace settings.
    Olof Ekbergh
  • Fermin Branger
    May 14, 2009 at 3:42 pm
    I agree with Olof. I’ve used JES Deinterlacer with great results too (for free).
    Fermin Branger
    ALFARERIA CINEMATOGRAFICA
    Caracas, Venezuela.
