Activity Forums VEGAS Pro Deinterlacing in Vegas Pro 13
  • Deinterlacing in Vegas Pro 13
    Posted by Evan Lindman on October 12, 2016 at 9:14 pm
    Hey, everyone!
    Title says it all.
    I filmed a wedding with one of my “film” friends. All of his groom preparation footage he shot in deinterlaced. -_- (I thought he knew how to operate his camera)
    I took the footage into Vegas, changed the field order to progressive scan, rendered my highlight film, but can still see some lines in his footage. What else can I do to make this footage look better?
    Plugins or something?
    László Kovács replied 9 years, 11 months ago 5 Members · 11 Replies
  • 11 Replies
  • Ole Kristiansen
    October 12, 2016 at 9:30 pm
    Did you use: Interpolate fields
  • László Kovács
    October 12, 2016 at 9:34 pm
    I assume you mistyped and the friend shot the wedding interlaced, not progressive.
    If you set the media properties to “progressive”, Vegas won’t deinterlace it, becuase it thinks it is progressive.
    Thus the lines a noticeable.
    Set it to the correct field order: “upper field first”.
    So the deinterlaceing will be done by Vegas.
    Another option is that you apply Yadif deinterlacer as mediaFX, this gives better deinterlace, than Vegas13 builtin (it is much slower as well). If you do this, no need to do another deinterlace by Vegas, so you can keep it flagged as progressive.
    Best regards
    László Kovács
  • Evan Lindman
    October 12, 2016 at 9:41 pm
    Edit to my original post: I meant to say my friend shot in INTERLACED footage. Was a typo!
    Thanks for the reply. I’ll give that plugin a shot!
  • Evan Lindman
    October 12, 2016 at 10:05 pm
    Never used that before.
    Just tried it, and it looks like it solved the problem. Is it used for motion blur in footage?
  • Wayne Waag
    October 13, 2016 at 2:39 am
    If you do try the the Yadif plug-in, remember that you have to set the Deinterlace method to “none”.
    wwaag
  • László Kovács
    October 13, 2016 at 3:48 am
    This is why I told to keep the progressive flag.
    But that option would work too 😉
    Best regards
    László Kovács
  • Steve Rhoden
    October 13, 2016 at 10:18 am
    Vegas needs a good De-interlacing plugin. Boris CC has one, but that’s overkill for someone looking
    for just this one feature.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • László Kovács
    October 13, 2016 at 10:52 am
    Steve, you’re knocking on an open door ?
    Vegas 14 has a new, adaptive deinterlacing method, which is just the same Yadif does.
    And for the previous versions there’s Yadif 😉
    Best regards
    László Kovács
  • Steve Rhoden
    October 14, 2016 at 10:31 am
    I know that László, im not talking about that feature which is applied to everything so to speak, im talking about
    having a bunch of events on the timeline and would like to de-interlace just one and two of them, then with an
    effective de-interlacing plugin available, you would simply drag and drop it on the clip you desire.
  • Wayne Waag
    October 14, 2016 at 3:23 pm
    I use an Avisynth filter QTGMC, considered by many to be the best, and much better than Yadif (although Yadif is an option) and certainly better than those inside of Vegas. It does require installation of Avisynth and Virtualdub and a script to control the round-trip processing from Vegas and back. In the past, I’ve used a single-purpose script to do this but have recently created a GUI version that can easily accomplish this with just a few clicks. It adds the de-interlaced file as a Take to the original event. It should be available in the not too distant future since it’s undergoing pretty much final testing. It also supports Deshaker for those interested in a freeware alternative to Mercalli.
    wwaag
